how can u tell if it broke?
Old Apr 15, 2005 | 11:14 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
how can u tell if your waterpump is bad/going bad?
is there a 4sure way to tell other then install a new one and see if that fixes the problem??
thanks in advance
Old Apr 15, 2005 | 11:31 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
What's the problem? Unless it's puking coolant out the weep hole or sounds like the bearings are going, it's probably not bad.
Old Apr 16, 2005 | 08:12 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
That's true - unless the impellar comes loose from the shaft. Pull the rad. cap off when the engine is cold, start it up and let it idle till the thermostat opens. When the t-stat opens, you should see the water flowing in the radiator. If the water kinda just sits there, you have problems. You should see a definate current in there.
That's how I check mine, and there's probably other ways too.
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
