V.a.t.s. help?
Old Apr 16, 2005 | 02:40 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
V.a.t.s. help?
I really dont know much about where this post should go. But...
is there anyway to tell which resistor was in the key for a 89 Iroc. (some code under the dash, or is there anyway to override the system?) I had the dealer look up the key but they dont have the vat# and i dont have the money for a tow, 1-2hours worth of work then a $40 key plus inspection.
Old Apr 17, 2005 | 09:52 AM
Vader's Avatar
There is no readily evident code on the vehicle that will directly provide information about the VATS pellet resistance.
Your first mistake may have been visiting the dealership. I generally advise that the dealership service departments are a good resource, and are frequently slighted when they may actually be the best source of information, but they are not locksmiths. Go to your local locksmith. Take the VIN and proof of ownership. They can decode the VIN, provide you with a resistance value (key blank code number), and cut the new key. I can get a genuine GM VATS key from a local locksmith for $9 (used to be $7 - inflation, I guess). The dealerships are hampered by their parts distribution system, and have to charge about $39. And they may cut a few before they get the physical cut correct. They might not charge you for the recuts, but you'll be pretty frustrated making 3-4 trips back for a good key cut.
You can also experiment with various resistance valuse to find the correct key pellet resistance, but you'll have to tear into either the column or lower dash, and will still need to get the key cut. Call your local locksmiths and ask around.
Old Apr 17, 2005 | 11:56 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
thanks, yeah they tried to look it up no vats code, um, got a key cut and drilled a whole in it looked up the resistors online and just plugged um in
Old Apr 17, 2005 | 02:34 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I broke my key off once and had to get a new one. I just brought proof of ownership (insurance and registration) to the dealership and they had me a new key in 20 minutes for $30.
I have since removed my VATS.
jdukate
Apr 30, 2015 04:38 PM
TheHog91
Apr 22, 2012 09:28 AM
duece
Oct 30, 2011 09:35 AM
mehanso
Sep 20, 2011 07:52 PM
