How can I verify I have a ZZ4 cam?
Old Aug 3, 2001 | 09:39 AM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I want to verify that what I have is in fact a ZZ4 5.7l cam or ZZ3 before installing it. Is there a certain stamp number I should see?
There are several # stamped on each end.
I posted this also in the TPI forum but figure it would get more visability here.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
Old Aug 3, 2001 | 09:51 AM
ede's Avatar
ede
you ought to be able to find a pn at jim pace or scroggin dickie sites to check against the pn on your cam, plus you could always measure the lift of it, duration would be a little harder to figure out.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 3, 2001 | 11:43 AM
2QUIK6's Avatar
The SD part# is 10185071, but that number is no where on the cam. On the rear end of the cam, the number 193 00L 071 FM14 is stamped on it, the only thing similar is the '071' part, is that it?
On my other post, a guy posted his stamp number and the only thing common between them was the 071.
Old Aug 3, 2001 | 06:03 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Read your post on the TPI board. I'd say its genuine.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
J-money
Jan 4, 2019 09:45 AM
skeltor
Feb 2, 2016 10:37 AM
Jorlain
Oct 8, 2015 01:57 AM
webeeZ28
Sep 14, 2015 12:00 PM
masonta
Sep 1, 2015 06:40 PM
