Air Conditioner help!
Old Apr 16, 2005 | 07:12 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
So while running the car to fix a cooling fan problem (see my post in "cooling") I look up and see smoke comming out of the A/C compressor! I had the A/C running to see if any of the fans would kick on....I have never seen a compressor smoke before...is that normally how A/C compressors go out? *** I love to hate this GM POS.
350Z
Old Apr 17, 2005 | 09:43 AM
Vader's Avatar
You may have a clutch slipping on the A/C compressor. You'll need to clean out any oil, coolant overspray, paint, or other contaminants from the compressor clutch. The problem is the same on any Ford POS, Chrysler POS, Honda POS, Toyota POS, BMW POS, Benz POS, Rolls POS, or any otrher POS you might encounter. As a matter of fact, it's actually worse on some of those other POS examples, since they have a designed smaller A/C clutch, which tends to slip more. The Harrison compressors are actually among the best.
Old Apr 17, 2005 | 11:12 AM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
Vader....cool...hey man when you say clean out the compressor do you mean remove it and take it apart of just use stuff like brake and/or contact cleaner....sorry I'm A/C retarded
350Z
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Thornburg
Sep 12, 2015 10:11 AM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
