alternator bracket
Old Apr 13, 2005 | 06:56 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
alternator bracket
my engine has 1 hole in the top left corner of the pass side head and 3 holes in the ds head. i am using a v belt setup and just running crank,wp,alt. i cannot seem to find a bracket that will work. i have a lwp and a vic jr intake. i did find a moroso mount 63842 but it looks to be for an alternator drive setup. will this work with a lwp and a v belt setup? looks like it mounts to the lower holes on ds head that are straight across from one another. can someone point me in the right direction?
Old Apr 13, 2005 | 07:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If your head has one hole on the pass side, you should be able to drill & tap the one(s) you need to complete the job.
What heads, exactly?
Why are you asking on the Carb forum?
Old Apr 16, 2005 | 03:23 PM
bubbz89's Avatar
Car: 1990 RS
what about this bracket here?
Old Apr 16, 2005 | 03:25 PM
bubbz89's Avatar
Car: 1990 RS
five7kid- i figured alot of carb guys use vbelts and would have more knowledge on custom app., you can move it if you need to. thanks
Old Apr 16, 2005 | 08:14 PM
five7kid's Avatar
We'll try both places.
I don't know why it wouldn't work if you've got at least one mount hole in the head.
Old Nov 15, 2005 | 03:53 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
any more info on the pictured bracket above? im basically looking for a mid mount bracket for my alt and ps pump to get the alt out of the way of the heads and make it look a little more "even" (my a/c and smog bracket has been completly removed)
Old Nov 17, 2005 | 03:06 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
that's a good pic to show where the holes are in the block that leak oil beneath your alternator.
Old Nov 17, 2005 | 06:12 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Get the March bracket, or the Summit one. Same thing.
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
armybyrd
Sep 26, 2015 03:37 PM
