What are the sensors that are on each cylinder heads???
Old Aug 3, 2001 | 03:14 PM
LastStop's Avatar
Are they the knock sensor(s)? I'm not exactly sure what they are. Any help would be greatly appreciated. Thanks.
BTW it's a '91 Z28 305tpi.
Old Aug 3, 2001 | 03:31 PM
ede's Avatar
ede
left is for the temp gauge and right is for the fan
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 3, 2001 | 03:38 PM
LastStop's Avatar
Then what is that sensor on the front of the baseplate(manifold)? I thought that was the temperature sensor.
Old Aug 3, 2001 | 09:19 PM
Damon's Avatar
There's actually 4 of them on some engines. Pass. head has the "last gasp" sensor as I like to call it. It turns on the fans at about 235-240* in case the ECM isn't controlling things correctly. Driver's side head has the sensor that runs the temp. idiot light. On my brother's 87 TPI there are TWO additional sensors on the intake manifold water jacket- one is the sensor that the ECM looks at for engine temp and the other runs the guage on the dash. Why 4 sensors? God only knows.
Old Aug 4, 2001 | 12:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The one on the driver's side between the #1 and #3 cylinders is for the temp gauge on your dash.
The one on the passenger's side between the #6 and #8 cylinders is for the secondary fan (or single fan).
Below that in the block is the knock sensor.
On the front of the intake manifold there is a temp sensor for the ECM, and the other is for the 9th injector (85-88 TPI only).
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited August 03, 2001).]
bamaboy0323
Sep 3, 2015 06:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
