How do I get it back in?
Old Aug 4, 2001 | 12:07 AM
TransAm383's Avatar
Im almost done wiring my engine bay but Ive hit a problem with the harness for the heater/AC controls. I got the old wires out okay but Im having no luck getting the new ones through that little hole in the firewall. is there a trick to this anyonw would like to share with me? Thanks in advance.
Old Aug 4, 2001 | 09:22 AM
Vader's Avatar
TA,
It's a little late now, but for anyone else doing this, it's a good idea to use the old wiring to pull the new wiring through. At the least, tie a strong cord to the ends of the wires being removed. You can use the cord to pull the new wiring through at any time later.
For your situation, I would suggest using a stiff piece of wire (solid wire, like a coat hanger) to poke through the body grommet and use it to pull a cord or wires through.
Good luck.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
