transporting engine
Old Apr 18, 2005 | 05:58 AM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
transporting engine
i bought a used 350 i gotta pickup tonight and i was wondering whta the best way to transport one in the back oof a pickup would be. I have heard of using an old tire to set it on but im not exactly sure if that works and how to set it on. Does anybody have any simple designs of lil wooden stands to set it on?
Old Apr 18, 2005 | 06:54 AM
EvilCartman's Avatar
Car: '82 Z28
Do the old tire trick, just set the oil pan down onto the tire. Then take a couple of ratchet or motorcycle straps to the front of the heads and tie them off to the side of the truck bed so it doesn't fall over. Load the engine back by the tailgate so that also acts like a stop.
Old Apr 18, 2005 | 08:27 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I just picked up two 350's yesterday and used a trailer. I didn't have two old tires handy, so I used two of the factory valve covers off the engines to set the front of the oil pans on then used a racheting type strap to wrap around the two engines to keep them from falling over. Drove 60 miles this way and it worked out ok. Just couldn't drive like I was running moon shine.
I also used a card board slip sheet and this helped keep the mess down, and the valve cover in place under the front of the motor because it will sink down into the card board with the weight of the engine.
Old Apr 18, 2005 | 09:12 AM
ede's Avatar
ede
old tire is hard to beat
Old Apr 18, 2005 | 12:45 PM
Car: 83 Camaro
Transmission: th350
so do you put the big dip in the center of the tire
Old Apr 18, 2005 | 01:43 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I use old tires with used engines, just put the sump part in the center and take it slow, no straps are needed as long as its a 15+ tire. If it's a new engine I use wood engine crates or the plastic one I kept from a global crate engine, best $100 I ever spent, well for transporting engines anyway.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
