305 vs 350
Old Apr 18, 2005 | 11:48 AM
magicman's Avatar
Car: 72 Cutlass Vert
305 vs 350
I'm considering buying a 88 iroc convertible with a 305 V8 with 100k on the motor. My understanding is that the 88 vert didn't come with the 350 due to torque concerns. How much would it cost to rebuilt the 305 when it's needed, and also can a 350 be dropped in instead? Any comments would be appreciated.
Old Apr 18, 2005 | 11:56 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Re: 305 vs 350
You can put a 427 if you wanted too...
Old Apr 18, 2005 | 12:04 PM
magicman's Avatar
Ok, but can the convertible frame handle a 350 or greater motor?
Old Apr 18, 2005 | 12:06 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
May need to stiffen it up a bit, sub frame connectors ect, but it can definetly be done.
Old Apr 18, 2005 | 12:25 PM
ledhead96's Avatar
305 rulesz. 8)
Get some gears, like 3.42.
Found mine at a local yard. $150 for the entire axle. 8)
Another $150 for the install [labor, break lines, diff oil change, etc.] and it'll feel like a new car.
Old Apr 18, 2005 | 01:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your convertable can handle a 350 without any problems. Swapping in a 350 is easy and everything from your 305 will transfer. You will get nothing but a smaller wallet if you rebuild your 305. Take some times and do a few searches on 350 swaps.
Old Apr 18, 2005 | 03:13 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
350 tpi's r sexy
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
