shiming a starter
Old Apr 18, 2005 | 10:35 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
shiming a starter
actually i dont think it needs shimmed but i could be wrong the starter needs to be closer to the ring gear .... seems to me that shims will move it away is that right ? if so how can i get it closer ? all the parts worked fine on the old block but maybe this new one is a little tight ... the block is a mid 70s 400 sbc stock type starter how ever the fly wheel is larger then stock and takes a 12 inch clutch but like i said it all worked fine on the old block ... any advice will help ... thanks
tao
the bell housing isnt stock and the fly wheel isnt hitting that...
Old Apr 18, 2005 | 10:52 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Putting a shim(s) on the outside bolt (away from the crank) kinda rotates the starter toward the flywheel/flexplate.
You gotta remember the starter doesn't sit "underneath" the flywheel/flexplate. It sits next to it. That's why the shims work.
Old Apr 19, 2005 | 12:15 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
thanks AJ ill give it a try ... tao
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
