Strange Sucking noise
Old Apr 19, 2005 | 12:06 PM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
My knowledge of cars unfortunatly is very limited. I cranked it up a little while ago and I heard a strange sucking sound coming from right behind the drivers side wheel, not sure if it's suppose to be there or what. But if anyone knows what it is please tell me, and sometimes it fails to start on the first crank. Signs of a future problem? or is it just showing its age a bit.
One last question, what kind of gas to you guys use? I've been using regular, its an 86 305 LB9 with 94,800 on it.
Also, there is also a clicking noise in the engine bay, a couple of people have told me that its the injectors, true or false?
Old Apr 19, 2005 | 12:36 PM
Andrew89tpi's Avatar
Car: 91 camaro rs
Engine: 350tpi
Here it is.
Old Apr 19, 2005 | 01:05 PM
MMroc86's Avatar
HUH?
So your saying its not a problem?
Old Apr 19, 2005 | 01:15 PM
Car: 91 camaro rs
Engine: 350tpi
Probably your vacuum line that goes to that canister is broke or disconnected. The canister could also be broke. Best thing would be to look in the fender to see if the line is connected. Shouldn't be too hard to figure it out though.
Old Apr 19, 2005 | 01:24 PM
Car: 91 camaro rs
Engine: 350tpi
The injectors probably are the clicking you hear because mine are pretty loud. Regular is fine to use. The vacuum leak is probably causing your starting problem. I meant to say vacuum tank not vacuum canister sorry for the confusion.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
3.8TransAM
Oct 1, 2015 07:47 PM
