Lifter valley oil restrictors
Old Apr 20, 2005 | 01:13 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
What is the purpose for lifter valley oil restrictors? Does the oil level fill up to where the vents are cut into the block and keep the lifters/etc covered in oil? I've never known what the purpose of these were...
(cut from a page of CHP)
Old Apr 20, 2005 | 01:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are to force the drainback oil to have only one route to go; which is chosen such that it runs down over whatever the builder wants to oil, and so that it's easy to filter any possible metal chips from the valve train out of it. Keep in mind also, that there also has to be a vent connection between the part of the crankcase where the crank is, and the part in the pic; so those standpipes have holes to allow air movement.
Old Apr 20, 2005 | 03:25 PM
ede's Avatar
ede
i bet 1/4 nipples would work just as well for less money
Old Apr 20, 2005 | 04:12 PM
bnoon's Avatar
What?!?!? Now that's just crazy talk... Using something that's cheaper and more readily available in place of a more expensive alternative could put those racer parts shops out of business! Don't let anyone else know that Home Depot, Lowes, and (insert corner hardware store name here) are the best places to find hot rod parts.
Old Apr 20, 2005 | 05:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Plain brass wouldn't be as pretty as blue anodized aluminum when you pull the intake off to show off to all your buddies.
Old Apr 20, 2005 | 05:25 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Bastard! I almost choked when I read that!
LMFAO!!!!!
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
RyanJB
Sep 14, 2015 03:39 PM
ericjon262
Sep 11, 2015 06:07 PM
dimented24x7
Sep 6, 2015 03:51 PM
