Electronic Spark Control, LB9 Vs. L98
Old Aug 5, 2001 | 02:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got the original LB9 ESC module in my 85 IROC which now is home to a TPI 355. I'm swapping a 165 ECM in very soon, and I wanted to know if there was a difference between the LB9 and L98 ESC and if so, how much? Thanks.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Aug 6, 2001 | 11:53 AM
Jim85IROC's Avatar
ttt
The IROC Homepage
Old Aug 6, 2001 | 12:01 PM
leirch's Avatar
The part numbers are different. So SOMETHING has to be different. I don't have a clue as to what it is though. I still have the LB9 knock module from my 87 if anybody wants it.
Brendan
Old Aug 6, 2001 | 01:14 PM
Vader's Avatar
Jim,
I know that the detonation sensor itself is different between the two engines, so the control may be calibrated to the different sensors as well. Functionally and electrically they are the same, but the operating parameters might be different.
Just a guess.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 6, 2001 | 09:19 PM
Jim85IROC's Avatar
Thanks guys. Since I already converted to an L98 knock sensor, and I'm upgrading to a 165 ECM, I spose now is the time to get an L98 ESC.
The IROC Homepage
Old Aug 6, 2001 | 09:20 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Or, you could convert to SD and then you only have to buy the Memcal.
eightsixseven
Dec 16, 2024 01:50 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
