Throttle Bracket for Performer RPM intake
Old Aug 6, 2001 | 02:41 PM
84TransAm's Avatar
The stock throttle bracket doesn't seem to work on the Performer RPM intake manifold without a lot of twisting and bending, which i'm afraid will weaken the cable and cause it to possibly hang up. Is there a specific aftermarket throttle bracket that will fit the Performer RPM intake? A Holley 600 squarebore sits on top of the intake.
1984 Trans Am, Goodwrench 350, TES Headers, Performer Intake, Flowmaster 80 Series, Holley 600 cfm & vacuum advance, and T5 with short shift
Old Aug 6, 2001 | 03:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Holley makes one specifically for their carbs.
ICON Motorsports
Old Aug 6, 2001 | 05:18 PM
Cosmik Debris's Avatar
Part number 20-95.
Old Aug 6, 2001 | 05:28 PM
Changa2's Avatar
The Holley P/N 20-95 is a combination bracket having a position for the accelerator and also a position for the 700 R4 TV cable.
I see that your running a stick. I don't know if they have one specifically for a stick? I guess I would be surprised if they didn't, but if not just wack off the the Auto position or just let it hang there.
The bracket mounts to the carb, not the manifold.
[This message has been edited by Changa2 (edited August 06, 2001).]
Old Aug 6, 2001 | 10:28 PM
iroc5speed's Avatar
I just installed my RPM intake and I just had to bend the bracket a little. I think the instuctions say to cut out part of the bracket, but all I did was bend it slightly, enough to put bolts in the holes. once you can thread the bolts, just bolt them in and the bracket will fall into place.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
mdtoren
Aug 23, 2015 12:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
