Ignition switch replacement?
Old Aug 4, 2001 | 01:23 PM
Ken88GTA's Avatar
What's next!?!?!?! I just spent 7 hours replacing my fuel pump and now this!
I'm noticing sometimes after starting the car, I don't have power to all my accessories. The cooling fans, windows, A/C don't work. The radio, mirrors, dash do. Thats all I've noticed so far. If I wiggle the key, they all start working again. Wondering if this could have had something to do with my pump's demise?
The ignition switch has always been a little loose, didn't seem to be bad enough to cause a problem. Do I just need to replace the switch itself or could there be another problem in the column? Also, how difficult is it to replace?
Thanks in advance!
Ken
Old Aug 4, 2001 | 03:06 PM
Vader's Avatar
You may have a defective ignition switch, or the linkage to the switch may be maladjusted (like most Honda drivers).
This may clarify things for you a bit:
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 5, 2001 | 08:39 PM
Ken88GTA's Avatar
Hey Vader,
Thanks for the pic. Are you referring to #63,ignition switch actuator assembly? How would I go about checking it?
Thanks,
Ken
Old Aug 6, 2001 | 10:21 PM
Ken88GTA's Avatar
anybody?
Old Aug 6, 2001 | 10:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The switch is held on the column by 2 screws. They go through slots in the switch. Get up under there and investigate it.
ICON Motorsports
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
