What are 95 lt1's running?
Old Aug 5, 2001 | 03:39 AM
Gta-Paladin's Avatar
I've got an 89 Gta with a 3" exhaust and highflow cat with K&N
Im wondering what else i need to beat a STOCK 95 lt1 manual
Old Aug 5, 2001 | 02:44 PM
camaroguy99's Avatar
you might get better responses if you posted this in the street racing forum, then once you find out what they are running repost here asking what will it thake to get into the 1x.xx?
I would answer you question directly but I really have no idea sorry.
Old Aug 5, 2001 | 08:08 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
well, it really depends on the driver there. my 94 with just over 100k on it went 14.07 with only mod being a ram clutch and an air foil. the clutch really was hardly a mod since the stock one would have been able to hold up if it were still in decent shape. that was 14.07 with a 60' time in the 2.3's. i'm going to figure out yet how to get this thing out of the 2.3's for 60'. stock even down to ac plugs and paper ac air filter. i have seen most at the track going 14.4's and 14.5s with average drivers though.
Old Aug 5, 2001 | 09:37 PM
And is that at sea level?
Old Aug 6, 2001 | 01:55 AM
iroc5speed's Avatar
my friend has a slightly modified '93 and he ran a best 14.5 on a bad strip, also his first time to the strip.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 6, 2001 | 03:07 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
At my track the stock ones all run in the 14.4/14.5 range. 9.3s/9.5s in the 1/8.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Aug 6, 2001 | 08:36 PM
zippy's Avatar
Engine: 5.3L
i'm a few hundred feet above see level. it varies per track i go to. there are three local.
Old Aug 6, 2001 | 08:54 PM
So basically, only the Ls1's are "OUT OF MY LEAUGE"... for now ??
Old Aug 6, 2001 | 10:48 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Was your 89 a dual cat 3.27 geared car originally? (I'm thinking not since you now have a single cat). That means you should be packing 2.77 gears. WEAK. If so that makes it more difficult, but still with just a few mods you'll be in range of the LT1s easily. The LT1s run around a 14.0/low 14 on average. You should be running around a high 14 now most likely with the 2.77s (assuming good state of tune, decent track).
Port your plenum, install a AFPR and bump the pressure up a bit, get at least some 3.2x gears (preferrably 3.4x), and install some headers and you should be in a much better position to take on stock LT1s...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
