Bad Vibe
Old Aug 5, 2001 | 08:31 PM
AustinT's Avatar
Bad Vibe
I have a bad vibration I only notice it crusing down the interstate at 75 in the 6th gear. The vibration goes away when I accelerate, or slow down. I have it when i Just maintain a speed with the throttle or when i Shift in neutral. I recently had a Torsen Hd Posi, new axles and 4.10s put in the rear. I didnt do anything to the drivline or u Joints. What Should I do first
Old Aug 5, 2001 | 09:57 PM
One Eyed Jack's Avatar
maybe its the lubricant in the rear end?
Old Aug 5, 2001 | 10:04 PM
AustinT's Avatar
Im using richmond gear oil GL6
Old Aug 5, 2001 | 10:48 PM
rezinn's Avatar
Have the driveshaft balanced and replace the u-joints. If it is at a certain rpm(as you notice at 75mph), it is most likely driveshaft related.
Old Aug 6, 2001 | 01:50 AM
iroc5speed's Avatar
with a posi rear you are supposed to use limited slip additive, maybe this will help, though if it only happens at high speeds it's probably the drive shaft-mine did that in my now stolen '85 Z28
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 6, 2001 | 11:52 PM
AustinT's Avatar
I am running a higher drivline speed. 3.08-4.10 Ill replace the ujoints and have it balanced again
thanks
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
