T56 4th gen slave cylinder not fitting 3rd gen pedal
Old Jul 31, 2001 | 08:21 PM
BOTTLEDZ28's Avatar
Transmission: A4
I just put a t56 in my 91z28 and now the clutch/slave cylinder doesnt fit on my pedal. the rod has a plastic bushing and it wont fit at all how did you guys gets yours on
Old Aug 1, 2001 | 01:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I think you need the slave cylinder from the T56. Or is that the one you're using? The stock thirdgen one wont work.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 1, 2001 | 12:03 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
You must be talking about the clutch master cylinder and it not working with the pedal. I have not done this mod so I don't know what your problem could be. Are you trying to use the fourth gen clutch master cylinder in your third gen with third gen pedals? I would bet that you need to use the third gen 5speed clutch master cylinder assembly. That way the rod will definately fit onto the pedal correctly. I'm not really sure.......... Check out the tech article on this site for swapping in a T56.
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, BBK 52mm TB, Edelbrock TES, gutted Cat, Flowmaster, CAI w/K+N cone, AFPR, TB bypass, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Alum. Driveshaft, Hotchkis STB, '99 Camaro seats.
Coming Soon!!: Fourth gen 3.42:1 rear, Spohn LCAs and Panhard.
Old Aug 1, 2001 | 07:22 PM
BOTTLEDZ28's Avatar
Transmission: A4
i am using the 4th gen clutch / slave cylinder on my 3rd gen pedals. i am running a t56 so i cant use my old t5 setup.
Old Aug 1, 2001 | 07:43 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
What do you mean by it not fitting? Is the hole at the end of the rod too small or does the rod not line up at all?
Old Aug 1, 2001 | 09:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
the hole on the rod is too small for the attachment on the pedal.
Old Aug 2, 2001 | 02:39 AM
Fbird88's Avatar
Car: 1988 Firebird
Axle/Gears: :(
I would also remove the bushing like others suggested. If it still doesn't fit, you could always enlarge the hole slightly.
Old Aug 7, 2001 | 10:12 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
If you remove the bushing, the hole is too big and the pedal will feel sloppy.
I've "heard" you can just force it on with a pair of vice grips and discard the retaining clip.
If you're good, you can modify the bushing so it will fit. I used a rat tail file and cut the top and bottom "lips" off the bushing (actually, one just comes off).
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
