LT1 starter on 3rd gen
Old Apr 22, 2005 | 11:34 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Have heard of a couple guys going this route when our starters crap out.
Who on here has done it? Any "problems" switching to a LT1 starter on a thirdgen (305)....or does it just bolt right in and hook right up?
Suggestions for replacement for someone with a toasted starter?
Thanks,
Dave
Old Apr 22, 2005 | 01:15 PM
87GTAspeeder's Avatar
Car: 1987 GTA :)
Engine: duh! 5.7 TPI
Transmission: Stock
I dunno about the 305, but I have a 350 and thankfully it was a breeze. Didn't need any shims, it bolted right in. The only trouble you might run into is the length of the wires might not be quite long enough to reach so you either have to extend them, or just replace them with better ones hehe.
Also I ordered mine from turbobuicks.com...Even came with the bolts. Good luck!
Old Apr 22, 2005 | 01:40 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Cool...anyone have any luck with a 305????
D
Old Apr 22, 2005 | 01:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is one of the commonly used alternatives.
Others include the various "mini-starters" such as CVR, Tilton, Powermaster, CSI, etc. etc. etc. Those are virtually all based on eother the Hitachi starter motor (all parts look round), or the Nippondenso one (has a round solenoid but sort of squarish-looking motor).
ANYTHING with gear reduction is better than that Stone Age direct-drive Delco POS that came in these cars stock.
Old Apr 22, 2005 | 01:52 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
So RB83L69 it will work on my 305 then? I wouldnt see why it wouldnt ...but then again you never know? The teeth and mounting holes shoudl all line up...right?
D
Old Apr 22, 2005 | 02:16 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I believe there may be an issue with flywheel teeth. You may have to get a different one but I can't remember. I also believe the Nippondenso is the one to get and not the Hitachi one. I did a search on this before and thats what I remember but I could be wrong. I think the flywheel issue depends on the year of your thirdgen. This is probably all rumors and conjecture so take it for what its worth...RB would know.
Old Apr 23, 2005 | 01:06 AM
CAH383's Avatar
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
As long as your car block is factory and has the smaller flywheel as it should. You can run that starter all day. I have one from an LS1 which is on all LS style engines. Just like the one on my 04 Silverado, so if my Z's ever goes bad there will be a swap and the truck goes in for warrany work for a bad starter
midge54
Dec 27, 2019 04:14 PM
Warlocksirix
Sep 3, 2015 12:26 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
