Quick!-_Help/Unhooked FuelPump Fuse and car still running after 10 mins
Old Apr 23, 2005 | 03:09 PM
IonNight's Avatar
Car: 1986 Iroc Z
Engine: Truck 305 /Bored .30 Flat Pistons/ Crane Cam
Transmission: Corvette 700R4
AM I supposed to let the tank go empty??? The car is still running now... I want to hook up a fuel pressure regulator to the shrader valve....
Opened Gas tank
Pulled off Fuel pump fuse
Started and let car run--- not dieing
Old Apr 23, 2005 | 03:20 PM
IonNight's Avatar
Car: 1986 Iroc Z
If I pull the fuse completely out while the car is running the car shuts off because of the ecm being with the fuel pump fuse....
I let it run with the fuse inside the prongs but outt the plastic piece it locks in to.... and the car never shut off it just kept running
Old Apr 23, 2005 | 04:30 PM
IonNight's Avatar
Car: 1986 Iroc Z
wow that was lame...
I didnt have to even remove the fuel pump fuse
or drain the fuel system
All I had to do was throw the Fuel Pressure tester on the shrader vavle and boom thats it
Old Apr 23, 2005 | 04:38 PM
Meatwad's Avatar
On Probation
Car: 1987 IROC
Engine: 350?
Transmission: 700-R4
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
