Fuel Line Question
Old Apr 23, 2005 | 08:26 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
Fuel Line Question
Hey guys I was just peeking under this IROC I picked up for short dough and realized that someone repaired the fuel lines with a rubber hose.
The location of this is basically in front of the left rear tire along the floor right where it bends at a rounded 90.
I have never had to drop the tank but my thought is it is one line all the way to the front of the car?
My other thought is it is one line from the top of the sending unit as well?
If I can get a digital shot I'll post it tomorrow. Just curious what you all have experienced. I am going to end up dropping the tank to fix it the right way regardless.
Old Apr 23, 2005 | 09:20 PM
onebinky's Avatar
You have three lines coming from the tank. One is pressure, one is return, and the third is coal canister feed.
Yes, they are all one length except for the pressure line. The pressure line is divided by the filter under the rear drivers side seat.
Old Apr 23, 2005 | 09:26 PM
TKO500's Avatar
Do you know how they are mounted to the sending unit? I want to replace the full line if possible.
Old Apr 23, 2005 | 09:49 PM
onebinky's Avatar
rubber line and hose clamps, IIRC. Threaded fittings for the filter.
Old Apr 23, 2005 | 10:34 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
If the rest of the line is in good shape, I would just remove the rubber hose repaired area and use hard line with compression fittings. PITA to do the whole line. Especially if you don't have to.
Old Apr 23, 2005 | 11:44 PM
onebinky's Avatar
If you go the compression fitting route, make sure you prep the steel line right. Gas leaks are no fun at all.
3/8" pressure line and 5/16" return, BTW.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
