Speedometer died :(
Old Aug 7, 2001 | 10:14 PM
mcconahay37's Avatar
Speedometer died :(
I just got my car fixed after breaking a rocker arm stud, breaking one pushrod and bending another, and somehow managing not to drop a valve into the cylinder because one of the vavle locks came off, and IMMEDIATELY my speedometer broke. It didn't even wait 30 seconds! The upper cable turns the speedometer if we turn it, so the guage and upper cable aren't broken. The lower cable seemed tight and acted like it and the gears in the transmission are ok. This leads me to believe that something in the cruise control unit that the two cables connect to is bad. How hard is it to replace this and about how much do they cost new or at a junkyard?
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
Old Aug 7, 2001 | 10:18 PM
breathment's Avatar
pull it out of where it goes into the tranny, and turn the gear there, if it turns the speedo, then its either THAT gear or something in the tranny. if it doesn't turn, then fallow it and unplug it ever time it connects to the cruise control unit etc. that should help u figure out something.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Aug 8, 2001 | 02:23 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The 82's had a cable driven speedo, so prolly the cable broke. Possibly the gear stripped out, but I doubt it.
It could be a PIA to disconnect the cable from the back of the cluster, there's a small sheetmetal screw (10mm head) down on the drivers side framerail, if you take this out it will give you the slack you need to pull the cluster out and squeeze the retainer to disconnect it.
InfernalVortex
Apr 20, 2021 11:31 AM
Gunner242
Dec 25, 2015 04:49 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Luigytico09
Oct 1, 2015 08:46 AM
