help me pick a cam
Old Aug 8, 2001 | 02:05 AM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
help me pick a cam
Ok i need to pick a cam for my 358ci 1980 to 1985 block
here is what i have to work with
dart iorn eagle heads
ported and polished
10.1 to 10.5 comp ratio
holley 750
edelbrock rpm air gap
3,000 to 3,200 stall converter
Now i would like to use a hydraulic roller cam made by comp cams and i want to make a minimum 425 hp any part numbers and info will be appreciated thanks Davd Wenzel.
Old Aug 8, 2001 | 06:44 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
depending on gearing I would either go with the XR282HR or the XR288HR. Should make 425hp easy.
Old Aug 8, 2001 | 12:38 PM
85transamtpi's Avatar
Call up Comp Cams @ 800-999-0853. They will ask you all about your setup (engine, trans, converter, gears, mods) and suggest a cam for you. They give you the specs on their cam so if you dont want a comp cam you can get one from another brand that is close.
junkcltr
Aug 2, 2019 11:12 PM
Street Lethal
Apr 30, 2019 12:14 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
