Car will not go into closed loop!
Old Aug 9, 2001 | 03:16 AM
86 IROCZ28's Avatar
My car will not go into closed loop and it is driving me crazy. I have checked everything, I unplug the 2 sensor at operating Temperature and it will not set a code. I measured the volts on the O2 sensor and it came back from memory around the 700mV
constent it did not vary voltage like it should.
I have a 160 thermostat in the car. The car heats up enough to get into closed loop I am sure of this as I also have an adjustable fan controller so I can set the fan to come on at at any temperature I like. Usually my car sits right on 160.
I chekced all the other sensors like the Coolant sensor and they all came back okay.
What do you guys suggest I look for??
Old Aug 9, 2001 | 09:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Some kind of short on the oxy sensor wire? I believe if the computer sees a steady voltage from the oxy sensor, it should throw a code (as long as all of it's other closed-loop-conditions are met).
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
gwade12
Aug 8, 2015 08:17 AM
