PLEASE HELP FAST! Cam change did something weird!
Old Aug 8, 2001 | 08:52 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I put the XE262 Comp cam in my 83 LG4 T/A. It made a BIG difference in performance. My problem is it will hardly idle. And when it does, it will run very rough and die out after like 30 seconds. From like 1200rpm and up it runs excellent. I couldnt find any mixture screws to mess with. Unless theyre still capped off. Does that sound like it could be too rich or too lean?? Please help though, this is my daily driver and I need it to run right. Thanks in advance.
Old Aug 8, 2001 | 09:28 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
The a/f mixture screws are capped and located on the base plate of the carb, on the front. Cut 2 slots on either side of each one from the bottom and use a punch to get the bottom part out of the way. Your mixture screws are right there. You may need a special tool from sears or some place to turn them, you'll know when you see them!
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.50@ 97 with carb... now converted to TPI
[This message has been edited by slowTA (edited August 08, 2001).]
Old Aug 8, 2001 | 11:34 PM
84L69TA's Avatar
Car: 4 Mopars total
Thats cool. Ill do that tomorrow. Do you think that will fix it? I know that with the cams ive put in before, ive had to adjust the mixture screws big time. Before i do that though, do you think that would most likely be the problem??
Old Aug 9, 2001 | 02:13 PM
87_T/A_LB9's Avatar
Do you know the specs for the cam? Odds are, if it was too extreme on the lobe separation, that would cause poor vacuum. When you go too low on vacuum then it will cause bad idle(which you are experiencing). However, without having the car in front of me, I don't know.
If you could list the specs of the cam, that would help us diagnose it a little better.
Old Aug 9, 2001 | 04:01 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
For reference the cam specs on the 262 are 218/224 dur @.050, lift of .462/.469 with a 110 degree lobe sep angle.
Hopefully you can get it running right with some tuning. I was afraid it might be a little too big to idle/drive well with your otherwise mild 305 auto though. Hopefully that is not the case... Good luck.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited August 09, 2001).]
Old Aug 10, 2001 | 12:10 AM
87_T/A_LB9's Avatar
I would say it's the vacuum at idle causing chaos with the computer.
Cleotiz
Jan 6, 2018 08:56 PM
maroe624
Apr 16, 2017 08:29 AM
Fast355
Dec 2, 2016 06:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
