temp guage needle
Old Aug 10, 2001 | 10:59 AM
NHcamaro's Avatar
temp guage needle
when I shut my car off and let it sit for a little while the needle goes past 260 and stays up there...then when I start the car I have to tap on the plastic to get the needle to come back down.. any ideas on how to fix this.
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
AOL: RyanNH84
Old Aug 10, 2001 | 12:26 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Replace The Gauge. It Is Bad. HAd A Similiar Problem With And Oil Gauge. I had To Tap It To Get It To Work. One Thing To Check Is When You Take Apart The Instrument Cluster, Check The Little Tabs That Connect To The Gauge And Make Sure That They're Making Good Contact. That To Can Cause The Needle Not To Work Right But Wasn't The Problem In My Case. I Had To Replace The Gauge. Best Of Luck
88' IROC-Z, 350 TPI, 700-R4
Old Aug 10, 2001 | 08:29 PM
NHcamaro's Avatar
it still works no ?
sheachopper
Jul 31, 2019 11:27 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
