no 02 sensor...limp home mode?
Old Apr 29, 2005 | 04:45 PM
rsn932's Avatar
does unplugging the 02 sensor put the car into limp home mode? i want to put a wideband 02 sensor in place of the stock one so i can do some tuning before i get a new bung welded in for it. or does anyone have any better ideas on how to hook up a wideband without having a bung for it just temporarily?
Old Apr 29, 2005 | 06:36 PM
Vader's Avatar
Yes, disconnecting the O² sensor will prevent the engine from entering closed loop mode. After a time interval with no reporting from the sensor, the ECM will set an error code and enter backup fuel mode. Of course, as with every hard-and-fast rule, there are caveats. The ECM will not enter Backup Mode if the Highway Fuel & Spark Mode is invoked. In HF&S Mode, the oxygen sensor input is basically not used. However, I think it may need to at least be present since the ECM must have been in Closed Loop Mode for a period before HF&SM can be invoked. Of course, that would require an active O² sensor first.
One possible alternative is to connect an O² simulator, but this may not work with the older control systems.
Old Apr 29, 2005 | 07:58 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
if its unpluged will the check engine light turn on? If so mine didnt when i got the car, it ran really good till i looked over my car.
Old Apr 29, 2005 | 08:18 PM
rsn932's Avatar
my service engine soon light didnt come on for about 10 minutes.
the car was running okay, a little lean while cruising and a little rich at WOT. time to weld in a bung for the wideband and get tuning.
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
sammy52401
Nov 11, 2015 07:20 PM
drumstixer
Sep 29, 2015 03:02 PM
ironbmt
Sep 27, 2015 06:00 AM
