283+350=302=
Old Aug 10, 2001 | 04:42 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
283+350=302=
Hi just wondering if i can build a
302 small block with a 283 crank that i have
plus a spare 71 350 eng out of a heavy half
ton truck ideas??...... thanks GTA
Old Aug 10, 2001 | 04:47 PM
ede's Avatar
ede
sure can if you get the crank welded up and then ground down, the journals are differant sizes. might be easier, better, and cheaper to buy a crank with a 3" stroke for a SBC.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 10, 2001 | 05:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes and no. Getting 302 cid does use a 4 inch bore of a 350 block with a 3 inch stroke from a 283.
The downside is that 283 cranks use 2.300" mains and 2.00" rods and a 350 block or any SBC block starting in 1968 uses 2.450" mains and 2.10" rods.
What this means is that the crank won't fit in the block. The mains are too small for the 350's bearing caps and you would have to use the smaller diameter 283 con rods.
A true 302 built in 68 and 69 used a large journal "steel" crankshaft. The ones built in 67 used a 283 small journal crank.
Since the chance of finding an original steel 302 large journal crank to fit into a 350 block are almost nill your best bet for building one is to buy an aftermarket crank. Don't forget, finding one means it's 33 years old and there's no telling what kind of condition it will be in.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 10, 2001 | 08:09 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
you could use a small journal 327 block and a 283 crank.. most of the 283 engines had steel cranks and are relativly easy to find... Kevin
Old Aug 10, 2001 | 08:15 PM
Tas's Avatar
Tas
you can use the crank from a L99. That is a 265 CID(4.3L v8) version of the LT1. Its not as strong as the old cranks. Its not steel. It is one piece rear main seal though.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Aug 10, 2001 | 09:31 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Or, if you still have the 283 block, bore it out, I believe the 283 will take .125, which brings you to 301.xx CI's, used to be the "first" 302 in the late '50's, early '60's.
Old Aug 11, 2001 | 07:32 AM
Bjase's Avatar
Car: 88 IROC
The aftermarket makes spacer bearings to make up the difference between the crank and block...
Old Aug 11, 2001 | 08:26 AM
ede's Avatar
ede
<font face="Verdana, Arial" size="2">Originally posted by Bjase:
The aftermarket makes spacer bearings to make up the difference between the crank and block...</font>
i'd like you to tell me who makes them or who sells them because i've looked for quite a while and have never found them. i know in the 70s it was common for someone to buy and use the spacers or thicker bearings but i don't believe they're around any more.
ICON Motorsports
1st & 3rd
[This message has been edited by ede (edited August 11, 2001).]
Old Aug 11, 2001 | 08:37 AM
Mike-91 Formula 350's Avatar
The small journal 327 block is the easiest way but good luck on finding off the shelf pistons that arent 11.0/1 By the way why would you want to do something to cut horsepower?
Old Aug 11, 2001 | 11:10 AM
AlkyIROC's Avatar
Car: 87 IROC L98
The only block spacers I've seen are for putting a 350 crank into a 400 block. That's not saying there are any out there but I've never seen any either.
You don't really cut HP but lose a lot of torque because of the short stroke. The 302 is a good road racing engine and could survive at 8000 rpm for a long time. At that high rpm you can produce a lot of HP.
[This message has been edited by Stephen 87 IROC (edited August 11, 2001).]
Old Aug 11, 2001 | 11:28 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mike-91 Formula 350:
...By the way why would you want to do something to cut horsepower?</font>
Not to start any arguments, but I've seen (and stood next to) 302s that make over 600HP. Granted, there isn't a lot of torque at the lower end, but HP=Torque X RPM/5250, so if geared and massaged correctly, the 302 can be a real punishment to most 350s as soon as they get near the 7,000 RPM region.
Have you ever have "trouble" with a 302 Ford? Same bore and stroke, dude. It's just that the Chevy has a stronger head, deck, and bottom end, and the potential for a lot better valve train than the Dorf 302 (or, 5.0, as you new guys call them - with a strong emphasis on the ZERO). I've also seen 348 Fords thatstarted life as a 302 and have improved the head flows, so be careful what you line up against.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 11, 2001 | 11:43 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Hey, doesn't trick flow make a 302 crank milled for the SBC?
Old Aug 11, 2001 | 12:43 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Would be kinda neat to see a 302 in a thirdgen since they did it to a fourthgen already.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Reborn756
Sep 4, 2015 03:42 AM
Bird_of_Prey
Jul 7, 2012 05:19 PM
Azarel
Dec 9, 2001 08:56 PM
blue86iroc
Aug 27, 2001 03:31 PM
Intense92
May 12, 2001 09:34 PM
