Installing Distributor
Old Apr 30, 2005 | 05:11 PM
klumb15's Avatar
I have a iroc z camaro, 350 with HSR intake...i was wondering, can you install the distributor with the motor in the car? because i was going to put my motor in today, but went to put the distributor in, and the housing is too big or something, it looks like i'm gonna need a new one....but that means i'll have to order one...but is it at all possible to put the motor in this weekend as planned, then slide the new distributor in there when I get a new one???
Old Apr 30, 2005 | 06:51 PM
rsn932's Avatar
mine went in fine with the motor in the car. the plenum was on too as well as all the fuel lines and vacuum hoses. ive certainly worked in areas with more space, but it can be done.
edit: just remembered i had to cut up the lip coming out of the firewall a little. the distributor itself fits down fine, but i couldnt get the cap down there. (and yes, it is the small cap style dizzy)
if you dont want to cut up that lip, im just about positive that it would go in no problem if you took off the plenum.
Old Apr 30, 2005 | 07:26 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
It should drop in easily without having to cut anything. The plenum can stay too. Leave the cap off it while you put it in. Gives you enough extra room to be able to do it.
Old May 1, 2005 | 07:14 AM
klumb15's Avatar
alright great...i'll put the motor in then worry about the dist. another point in time...
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
