valve train assembley question
Old Apr 30, 2005 | 08:47 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
i have trick flow heads and i got all the stuff with them
question is where the washers go(or is i need them)
head - guideplate - washer - 3/8" screw in stud - rocker arm - poly lock
or does the washer go in a different order if so let me know i want to get these bolted on tonight
doug in texas
Old Apr 30, 2005 | 08:58 PM
Engine: 350ci
aagggg
delete this!
the washers are for use on the head bolts that you pull off the car but i bought arp bolts so i have a washer festival now, weeeeeeeee. me and my paraniod self.
Old Apr 30, 2005 | 09:53 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
If your not running guide plates you put those washers under the studs.
Old May 3, 2005 | 08:48 AM
Engine: 350ci
really?
guess that makes more sense, i counted the same number of head bolts to washers so i guessed thats what they were but that sounds more reasonable. i have the non self aligning rockers so i gotta have guide plates. yay!
Vintageracer
Jan 10, 2020 05:33 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
