Need Help Quick Please!!!!
Old May 1, 2005 | 06:45 AM
Marlboro Man's Avatar
Car: 1984 Trans Am
Transmission: 5-speed
hey guys well heres the problem, I have an 89 firebird with a 2.8. On my way home the car just died, i towed it to my buddy's house and did some checking out, i was doing 65 mph with the cruise on by the way and there was no warnig just a shut off. the rotor would not turn with the engine so we checked the timing chain, sure enuff and soon as we pulled the cover off the chain fell out, we replaced it, but found that the cloys timing gear does not have a dot like a normal chain has it has like a bulge looking line, so we went off of that, and set both at 12 o'clock per the computer at my dads shop haynes says top gear at 6 and bottom at 12, well we could not get it to run that way so we put them at 12, well heres the problem when we hook the battery back up the lights flash and the internal alam goes off "speaker under hood is disconnected" there is a toggle switch next to the diagnostic port and it shut the alarm off when the key is on, but the engine will not turn over or anything, the fuel pump kicks on and you here a rattle at the intake, but the security light stays on, except for a few times and it went out but the car still would not turn over, please help if you needs more details let me know
thanks guys
Old May 2, 2005 | 04:19 AM
Car: 1984 Trans Am
gonna try somethin
Im goin to try the resister thing out and see if it works later on today, if it dont work ill holler back
Old May 2, 2005 | 07:06 AM
Car: 1984 Trans Am
please delete
moderators please delete this post i have updated it and placed it on another topic
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
