Miss Fireing ?
Old Aug 4, 2001 | 07:16 AM
RS91's Avatar
Miss Fireing ?
I Just Replaced my TBI and ECM. Now my car is miss fireing. What could be the cause of this?
Note: My Car has not been running for a few months until I replaced the TBI and ECM. Only problem now is miss fireing even at Ible...
Your help will be greatly appreciated.
Old Aug 4, 2001 | 09:17 AM
Vader's Avatar
RS,
I trust you used the original PROM from the ECM that was removed from your car. The replacement ECM may not have had the correct PROM for your engine installed.
You also need to understand that when you initially start and run your engine with a reinitialized or "erased" ECM, the ECM will not enter Block Learn Mode and write correct fuel and spark offsets for your engine until it has been in Closed Loop mode and operated under varying conditions for about twenty minutes. Your ECM needs to re-learn the sensor inputs and devise trim factors for your engine before you can expect normal operation.
Still, there should be no spark misfire. It is possible that the ECM is controlling the mixture more lean or rich than your engine requires, and is causing rough idle. If you have a true spark misfire, that has little to do with the ECM and you need to assess the ignition system separately.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 12, 2001 | 04:59 AM
RS91's Avatar
I Replaced all the spark plug and the engine now is working fine...
thanks for all the help now I can start using my car.........thanks
KCG
Jun 24, 2020 04:33 AM
PurelyPMD
May 5, 2016 04:57 PM
L98GTA87
Oct 19, 2015 10:43 PM
BLK87Z
Sep 18, 2015 11:29 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
