Showing 3 codes.....what do i do?
Old May 1, 2005 | 05:01 PM
90tagta's Avatar
Car: 1990 Trans Am GTA
Transmission: 5-Speed
I had my car looked at cause my service engine light was coming on and 3 codes showed up. They were42( est bypass failure), 43(esc failure), and 46(pass key). Where should I start to fix these problems.
Old May 3, 2005 | 08:03 PM
90tagta's Avatar
come on guys someones gotta have an idea.
Old May 3, 2005 | 08:40 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
......That's a group of codes you don't see everyday........... Damn....... Well first....by passkey, I assume it's a VATS code....Vehicle Anti-Theft System...? Does the car start, or have you ever gotten a turn-key and no crank, where you have to wait 10 mins or so to try to start it again? If so I imagine that's where that code is coming from...
Now EST or ESC.....my memory tells me that's something to do with your computer-advanced ignition timing. Check the connector for it....I THINK it's a single-wire connector somewhere on the passenger fender. But it's been a LONG time since I've worked on a GM......
That's the most help I can offer right now! Hopefully someone better will chime in.
Old May 4, 2005 | 08:17 PM
90tagta's Avatar
Ok my ignition switch was ****** so i installed a new one(which sukd) but my service engine light is stil someing on. Any other ideas on wat i could do.
Old May 4, 2005 | 09:19 PM
Nixon1's Avatar
Did you reset the ECM when you changed the switch? If not do that, and see what codes come up again, that way you can make sure you're getting fresh codes, not ones for stuff you've already fixed.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
3.8TransAM
Oct 1, 2015 07:47 PM
