Curious about Oil Pressure
Old May 2, 2005 | 08:56 AM
BGRshark's Avatar
Car: 1982 Trans Am
Engine: 305 V8 with a 4 bbl
Transmission: Stock Auto
Hey. I know all about too little oil pressure, and the disastrous effects that can have. However, is there such a thing as too high oil pressure. It got me thinking the other day when I watched my gauge move past the 45 to about 47ish for the first time ever. If it can be too high...what would be a cause/fix for this?
Old May 2, 2005 | 11:26 AM
ede's Avatar
ede
47psi isn't too high. yes you can have too much oil pressure.
Old May 2, 2005 | 03:24 PM
BGRshark's Avatar
Car: 1982 Trans Am
Just for idle curiousity now, what would be to high of an oil pressure? Again, what would be the cause of this, and what could be done to fix it?
Old May 2, 2005 | 05:14 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i dunno, but my L98 just got rebuilt with a melling M55 oil pump, and it pushes max on the gauge on start and will dwindle down only a little after it's been running. i don't think that would be normal, but the engine barely has 300 miles on it...
KAM
Old May 2, 2005 | 05:17 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
My digital oil gauge peaks out when it's cold, and when I drive it. When warm, idle pressure is at sixty or something. When I get around to it, I'll hook up a calibrated mechanical gauge and see what the pressure really is.
Old May 2, 2005 | 11:04 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Mines around 65psi at 1000rpm right off a cold start, and is about 40psi at 1000 when warm.
(This is with a mechanical guage BTW)
Old May 3, 2005 | 08:21 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I have seen 90psi on mine once or twice right after a cold start-up off idle. However, I have my bypass blocked off.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
