Emissions legal heads for a 427 stroker
How goes it fellaz,I'm gonna build a 427ci.stroker using a World Castings Motown block as a starting point.I need some input on some emissions legal heads that will flow good and pass the sniffer.....thanks 87 WS6 T56 T/A
I'm not to clear on Wa. smog laws but in cali you can only but the same engine in that came with a car of the same year. so a 427 in a thirdgen wouldn't fly. Just giving you a heads up do you don't get in trouble once it's in.
To answer your question, I've heard the trick flows are an excellent head for SBC but haven't heard anything on BBC. If you do go with them then you have to get the R series heads. they don't make a 23* for BBC. World products heads BBC heads are very good for the money you might want to check those out also.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
He's making a 427 small block, not a big block.
There are tons of smog legal heads, like AFR and Trick Flow.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the same issue still applies. This thing will not pass emission. neither on paper bc of the incorrect motor nor anytype of sniffer test. A motor that size will not put out anywhere near the same NOX and CO numbers a 350 would (even with a stock cam)
Do like RB does, put your stock motor back in for the test and then go back home and change it out to the perf one.
[This message has been edited by jcb999 (edited August 13, 2001).]
Actually, it might be able to pass if it is done right. Externally, the engine looks the same, and the only difference from the outside is in the lifter valley which would require the intake to be removed to even see it. Guys get 383 stroker motors to pass in Cali all the time. A good set of smog legal heads, and careful tuning will take care of it.
Car: 89rs
Engine: 400Sb
the displacement of a 350 and 383 are not that far off from a sniffer standpoint. You could get the sniffer to think a 383 is smaller. 10percent additional displacement insignificant. 22+percent is not. you will have to have it extremely lean, and hot. It will not pass NOX limits like that.
<font face="Verdana, Arial" size="2">Originally posted by camaroguy99:
427 small block my ***
[This message has been edited by camaroguy99 (edited August 13, 2001).]</font>
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
Ok, sorry I didn't realize there was a "427 small block". I guess I have to read up on these things beofre I open my big mouth. Would a regular SBC head fit on that block? I would think the bore would have to be larger and therefore a larger combustion chamber in the heads. Once again this is me thinking out loud so feal free to set me strait, again.
Mickeyruder
Sep 2, 2015 02:45 PM
