Underdrive pulleys?
Old May 4, 2005 | 09:27 AM
daddy33's Avatar
Car: '85 Camaro
Underdrive pulleys?
i looked in the Moroso catalog and they have the underdrive crankshaft pulleys along with the water pump and other ones. With the crankshaft pulley it shows a 30% and 50% underdriven ratio. which one is better to use? i know there must be a differenece but which one will be the best to go with?
Old May 7, 2005 | 11:58 AM
Vader's Avatar
Is there some reaon you need to reduce the speeds of your accessories? Does the Moroso information include a dyno sheet demonstrating any change in engine performance with eother swet of sheaves? I'd want to see that before installing any different diameter sheaves.
Try the SEARCH function. You'll see a lot threads regarding the typical problems generated as a result of installing underdrive sheaves, and precious few showing any actually measured improvements.
Old May 7, 2005 | 09:41 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
underdrive pulleys are just another form of snake oil.i myself have a set of March underdirve pulleys and i saw no change in preformance.if you buy a set don't expect nothing more than a little more "Bling" under the hood
Old May 8, 2005 | 08:53 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Have the March underdrive crank and pump pulleys on mine. No real problems but I doubt there's any real power increase either that I can feel. Look real nice.
Old May 8, 2005 | 11:03 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
What is eother,swet, and sheaves?
Old May 9, 2005 | 12:52 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That's called a White Russian with a ScrewDriver having Sex on the Beach.
Old May 9, 2005 | 01:03 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i know i don't have any slips to back up my claims, but i have a few buddies who have gained a tenth to 2 1/2 tenths with just pulleys. most everyone has claimed an increase in fuel mileage too, which is the biggest reason i want to get some...
Old May 9, 2005 | 01:15 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
That sounds about right
Old May 9, 2005 | 07:22 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Where do I sign up for this?
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
