Heat Crossover Blocked?
Old May 4, 2005 | 11:38 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
My car seems to take forever to warm up. I always have to let it stay in fast idle for a long time in the morning before it will idle properly. I talked to my mechanic about it and he said that the heat crossover in the intake manifold might be clogged up with carbon deposits and stuff. It's an edelbrock manifold but it's been on the car since October of 1987(previous owner). Does this sound like it could be the cause of my car's cold-natureness?
Is this an easy project to clean out the heat crossover?
Old May 4, 2005 | 11:47 PM
sellmanb's Avatar
Car: '86 Berlinetta
honestly, I've never heard of a heat crossover.
It sounds similar to what happens with the EFE valve though. Since you have headers you probably got rid of the EFE valve though, so that shouldnt be a concern.
You might want to check some of the simpler things first.
Is your thermostat stuck open? If it is then this will slow down the heating up process a lot.
Fan stuck on all the time?
Check those first.
Old May 5, 2005 | 01:10 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I think he is talking about the heat riser that crosses the middle of the intake. I have a 91 with the LO3 and it uses coolant as a heat riser instead of exhaust. Older chevy's had ports coming from the 2 middle exhaust valves that lead into a small chamber under the intake plane. Yours may use the exhaust but I'm not for sure.
I would do as sellmanb says, check the simple stuff first. A stuck thermostat can cause many cooling woes.
Old May 5, 2005 | 02:30 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Nope, its your choke.
Old May 5, 2005 | 02:36 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
which eldlbrock manifold is it ? alot dont have that passage its blocked off. i had that problem and it was thermostat stuck open.
Old May 5, 2005 | 02:38 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What carb is it? I'm still betting choke!
Old May 5, 2005 | 04:14 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I intentionally plugged my exhaust crossover in the manifold I put on my 350 in the fall. It got down to -56* a few times here and I never had any warm-up problems. All it does is warm up the intake, so the carb warms up. You don't need it. My engine actually works better with it plugged than it did before. A plugged up exhaust crossover will not cause warm up problems. Hasn't on any of the cars I know of with that plugged.
Old May 5, 2005 | 04:24 PM
vrtc350's Avatar
Car: 81 Corvette
I have a set of vortecs and they removed the crossover completely. Just shows that it is not nescessary. If that was even the case it would take a rediculous amount of carbon to plug that passage.
You can buy gaskets that intensionally block off the crossover.
Old May 5, 2005 | 07:36 PM
Air_Adam's Avatar
I just filled mine with hi-temp silicone, and cut a tin plate to cover each hole, and stuck it in the silicone.. works great.
Old May 5, 2005 | 10:54 PM
85cmroz28's Avatar
Engine: L69
The choke is working fine(Holley 600 w/e-choke). I just replaced the thermostat. The Edelbrock manifold does have the heat riser.
sailtexas186548
Feb 17, 2017 03:07 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
bryan623
Sep 19, 2015 10:13 AM
BLK87Z
Sep 18, 2015 11:29 PM
