Chipped tooth
Old Aug 12, 2001 | 10:01 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Chipped tooth
Or broken actually,
On a rear with 3.73's there is a broken tooth on the ring, obviously has to be changed eventually, richmonds replacement is 258.99, not familiar with them, is this a good price and how long would curent ring last as is?
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Aug 13, 2001 | 10:48 AM
RW91B4C's Avatar
Sound high to me, check JEGs or Summit for a good price. I wouldnt wait too long to replace it, if the gear brakes as your driving it could lock up the rear and you could slide off on to a ditch or wreck your ride!
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Aug 13, 2001 | 11:14 PM
iroc5speed's Avatar
my rear got some chipped teeth, and it lasted probably a week before I couldn't drive it anymore. Get that replaced right away.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Oct 3, 2015 01:25 PM
