ac swaping v to surp. pulley
Old Aug 14, 2001 | 12:06 AM
jaymz's Avatar
I have a 86 IROC that I want to install a surpentine belt system on. I have a good vbelt compressor on the car and a bad compressor with a surpentine clutch how can I swap these. Thanks
Old Aug 14, 2001 | 01:54 AM
Russ-So Cal's Avatar
You need to get a special snap ring plier designed for G.M. compressors. There is also a special puller to remove the clutch with. I don't think they are very expensive, but I bought mine in 1976, so I haven't priced them lately.
Old Aug 14, 2001 | 07:29 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I too thought it was that simple. Had a V-belt and serpentine compressor. Too easy I thought. Well, turnes out the compressors are differant under the clutch. The front housing cover on the compressor needs to be swapped also, you'll see this after the clutck is removed. Be careful and work slow, you don't want to ruin a good comprssor.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
