Lg4 worth putting 1.6 rockers on?
Old Aug 12, 2001 | 10:22 AM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
Im planning on putting a 350 in my sports coupe eventualy, but i wont to get more power out of the lg4 and use parts from the lg4 later on the 350.Anyone put 1.6 on lg4 and what was the results?
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
Old Aug 12, 2001 | 11:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I doubt it would make a big difference in power. But going from stamped sheet-metal ones to real ones would probably make the engine just run better overall, from the valve motion being so much more consistent from one to the next. They shouldn't hurt anything though.
ICON Motorsports
Old Aug 13, 2001 | 09:58 AM
ATOMonkey's Avatar
The springs won't take it, plus I'm not even sure that they're tall enough not to bind. Before everything breaks though you should see a boost in low end performance.
Old Aug 13, 2001 | 11:18 PM
iroc5speed's Avatar
I'd say go for it. I'm going to put some on my lg4 one of these days, but I'm going to get new heads first. Gonna change my valve train all at once. Should add at least a few horses. Every little bit helps, and they will also allow for better modifications to be made and be the most effective.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 14, 2001 | 05:06 PM
How does the performer rpm run on the lg4?
Old Aug 14, 2001 | 10:14 PM
iroc5speed's Avatar
oh it's awesome, though I have a new carb(and a new distributer to make it all work). It adds a lot more power to the car, especially at the top end.
'86 IROC 5-speed
305 LG4
msd pro billet hei
'95 3.23 rearend
midge54
Dec 27, 2019 04:14 PM
Cameeeero
Sep 18, 2015 04:00 PM
LT1Formula
Aug 20, 2015 09:36 PM
happyhapka
Aug 15, 2015 04:42 PM
