Engine Knock on start-up (Non Thirdgen)
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My moms got a 96 Maxima and it like to knock about 3 seconds on startup when the engine is cold. Is there a reason why? Car has 86,000 and runs Mobil 1 and Motorcraft Filter.
wiat a sec, isn't motorcraft the ford brand?Though I don't think this has anything to do with knock. You should check the timing, and make sure you're using the recommended grade of gas.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
'86 IROC 5-speed
305 LG4
msd pro billet hei
'95 3.23 rearend
Car: Formula
Engine: 6.0 LSX
There is no Distributer it runs on DIS and yes I'm running 91 or bette rlike the manuel recommends. It sounds like stating a motor right after an oil change.
Car: yep
Engine: uhuh
Transmission: sure does
Has it always knocked on startup with the motorcraft filter??
Some filters bleed down when they are shut off.
This will cause an engine knock until the filter "re-primes" itself.
I would try a puro-later, mobil1, or any other brand (besides fram) and see if this changes anything.
I've had good luck with AC.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: Formula
Engine: 6.0 LSX
Wait my mistake. It knocks with a bostch filter, autozone filter(deautch or what ever)um and thats it. I used to run motorcraft filters and do not remember it knocking. AC doesnt make a filter for the car. i checked and asked.
Car: yep
Engine: uhuh
If it didn't knock with the Motorcraft, I would switch it back to see if the problem goes away.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
