Estimate My Horsepower
Old May 7, 2005 | 09:45 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I have never put my car on a dyno and I wonder how much power the motor is making.
It is a 305 with a LT1 cam (Specs in my Sig.) The heads are LB9s that were shaved .030 for about 9.5 to 1 compression. It is topped off with a Holley Street Avenger dual plane manifold and Street Avenger 670 carb.
The car also has headman shorty headers and a free flowing exhaust.
Anyone interested in guessing how much horsepower a combo like this is capable of producing?
Lance
Old May 8, 2005 | 12:18 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My guess is 270 at the flywheel.
Old May 8, 2005 | 12:19 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
230-260hp
Old May 8, 2005 | 09:02 AM
Max's Avatar
Max
Thanks for the input.
Since I built the engine, I may be a little too optimistic. But, if you think about it, the Corvette LT1, which the cam shaft came out of, had a 350 rated at 300 horsepower. So, if you do the algebra, you come up with about 260 hp in a 305.
Of course it's going to depend greatly of the tune up. I use an Autometer Air/Fuel Ratio meter and a G-Tech performance meter to tune it. So, I think the tune up is near ideal.
Anyone else care to comment?
Old May 8, 2005 | 11:15 AM
sellmanb's Avatar
Car: '86 Berlinetta
the heads arent as free-flowing as LT1 heads, you probably dont have as much top end as the LT1s do because of it. I would guess around 245hp.
Nice setup though, it looks like you just need some better worked over heads and larger valves for bigger gains.
Old May 8, 2005 | 07:48 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Nice engine!
For that last little bit of performance follow the link at the end of my sig and follow the instructions. It'll be worth 30 more hp.
And finally, a nice little 2500 rpm TC will knock a full 1/2 second off the old quarter mile
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
formula_novice
Sep 5, 2015 03:58 AM
