V8 AC in V6
Old Aug 13, 2001 | 04:34 PM
ADAM NEAL's Avatar
V8 AC in V6
I have a 90' RS with a 3.1 and currently have no AC at all.It was removed before I got it.I have a chance to get an entire AC setup from an 86'Z28.Will any of the parts work from the Z28 on my car?Thanks
Old Aug 13, 2001 | 09:19 PM
ADAM NEAL's Avatar
Anyone?
Old Aug 13, 2001 | 11:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Everything but the brackets to mount the compressor to the engine. Hose length may be intersting, too.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 13, 2001 | 11:49 PM
ADAM NEAL's Avatar
So If I bought all the parts from the Z28 and got new brackets and hoses it would work?
Old Aug 14, 2001 | 01:51 AM
Russ-So Cal's Avatar
No problem, the a/c in G.M. cars and light trucks are the same. The only differences have to do with hose lengths for various applications and the brackets for various engines, and of course the change from v belts to serpentine.
Old Aug 14, 2001 | 04:10 AM
ADAM NEAL's Avatar
Thanks a lot for the info guys.
Old Aug 14, 2001 | 07:13 PM
irocbsa's Avatar
Be careful man, that 86 Z will have a V-Belt setup. Doesn't your car have the serp setup?
bsa
Old Aug 14, 2001 | 08:20 PM
You will have to change the clutch over from
v belt to serpentine. It's not a big deal.
You need a G.M. clutch puller, and special snap ring pliers. Any a/c shop could change it over for you. If you walk in with the compressor and new pulley/clutch in hand, it shouldn't cost much to have them change it over for you.
Old Aug 15, 2001 | 02:32 AM
ADAM NEAL's Avatar
Ya it is a serp setup.I never thought about that.Oh well. It's a hell of a lot cheaper to buy everything else used.Thanks man.
Old Aug 15, 2001 | 01:03 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I have all the stuff from a 91 V6 car if your interested make me an offer. I have the lines and everything. Still had cold and I just removed it last Saturday.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Aug 15, 2001 | 01:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is the compressor also on the driver's side for a V8? I thought I remember seeing some funky-looking a/c hard lines on the passenger's side of the V8 I worked on lonnnng ago... brharris's deal would be the best bet.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 15, 2001 | 07:20 PM
ADAM NEAL's Avatar
Brharris,I will offer you around $300 for the set up.Email me at jneal84@home.com asap and we'll talk about it.Thanks
