Cowl Induction
Old Aug 14, 2001 | 12:53 PM
WooshGTA's Avatar
Cowl Induction
Hey guys I'm a new member, just bought an 89 GTA a few months ago. I've never been too big into cars but I'm certainly trying to learn alot now. My car is pretty much stock except for a Flowmaster that was put on there before I got it. But I just bought myslef a used "fiberglass hardwood hood." I don't know much about it, I mainly bought it for style because I think it will look good on my car.
My question is what exactly does this hood do for performance, if anything? I've also seen it referred to as "cowl induction." Like I said I'm pretty new to the game...any info is really appreciated and I'll probably have further questions in the future. Thanks alot guys.
<img src="http://abacus.sj.ipixmedia.com/abc/M28/415b345ee82d4bdf223d7ad137/i-1.JPG>
[This message has been edited by WooshGTA (edited August 14, 2001).]
Old Aug 14, 2001 | 01:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Welcome aboard, this website will teach you many things about your car and others,
The main purpose of the hood is for underhood clearance. Some applications whether it be a taller intake manifold or your airbreather sticks up higher than stock need extra room under the hood. So if you have say a 3" cowl hood, then you have that extra space.
Cowl induction can also allow for some extra air to enter through the back of the hood depending on the type of hood you have. This allows colder air to reach the air filter, however this isn't that beneficial for performance.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 14, 2001 | 01:14 PM
WooshGTA's Avatar
Thanks for clarifying. As far as the extra space goes (I think it's 3 inches), what kind of stuff could I stockpile under there that wouldn't normally be able to fit?
Old Aug 14, 2001 | 01:20 PM
RW91B4C's Avatar
You also loose around 40lbs off the nose of the car. lighter = faster! It will improve braking and handling too
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.92@125.2 1.55 60FT. ON MOTOR - ET-STREETs w/MUFFLERS
Old Aug 14, 2001 | 01:21 PM
WooshGTA's Avatar
Awesome, that's what I was hoping to hear. Thanks.
Old Aug 14, 2001 | 01:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Cowl induction looks like a scoop turned around backwards. What it does is connect the rear of the hood to the high-pressure area at the base of the windshield, which is the best place to locate engine air intake. NASCAR cars for instance use that; if you look at one of those, the air intake is in the surface of the hood or the piece right behind it depending on the body, as close to the windshield as they can get it. Cold air can be a significant boost to performance, easily 2 or 3% HP improvement in most cases and sometimes even more than that, I can't imagine how anyone would think that wouldn't be beneficial.
With 3 extra " you could fit a better intake manifold and/or taller air cleaner if you had a carb. In a 89 GTA which has TPI there's little or no functional advantage, since it doesn't fix the fundamental bad design of the engine's air intake system in that chassis.
OBTW it's "Harwood", a brand name, not "hardwood"... the mental picture was pretty rich...
ICON Motorsports
Old Aug 14, 2001 | 01:29 PM
Car: 99 Formula
Axle/Gears: 342
Sorry I guess I should have not said it would not be beneficial, I really didn't think that, that much air could be allowed to enter through the back for that much HP.
Old Aug 14, 2001 | 01:40 PM
WooshGTA's Avatar
Ahhh Hardwood brand name, thanks. There's one less stupid thing I will be saying!
Here's an actual picture of the hood.
http://abacus.sj.ipixmedia.com/abc/M...7ad137/i-1.JPG
Old Aug 14, 2001 | 10:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
One thing that will really aid in the use of the cooler, more dense air near the windshield is if you close off all under hood air to the air cleaner. They have kits that you can buy for this, or you can make your own. All it is is sheet metal. Just make it reach all the way to the firewall, wide enough for the cowl portion of the hood (actually wider), and cut a hole in it so that it will fit around the TB. If you have TPI (which I'm sure you do) then I'm not sure how you can direct the air to the front. But I'm sure you'll figure it out. Maybe people on the TPI board know how. But then just apply foam rubber (the black stuff) around the edge of the sheet metal so when you close the hood, it'll seal out the under hood air.
As a rule of thumb, 10 deg cooler intake air will gain 1% HP. So do it!!!!
AJ
Old Aug 15, 2001 | 06:52 AM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey WooshGTA, welcome to the group man! Lots of helpful info here. Good luck with the car man, and good choice of a car if I do say so myself.
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Aug 15, 2001 | 10:57 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the biggest problem I have found is that there are no common parts to seal the cowl area to the aircleaner. You really only get the benefit if the air can't go to other areas under the hood. I heard about someone making one for a 1st gen. I am going to try starting with that
http://www.geocities.com/casanoc/
Old Aug 15, 2001 | 08:06 PM
Andy89RS's Avatar
<font face="Verdana, Arial" size="2">Ahhh Hardwood brand name, thanks. There's one less stupid thing I will be saying!</font>
No "d" in the name, it's Harwood.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
aharvel50
Sep 21, 2015 07:31 PM
