Pwr window fix, cleaning up the tracks.
Old Aug 14, 2001 | 10:25 PM
R.O.B.'s Avatar
I tried this on the body/interior board too, just thought I'd have more luck asking here also.
I've completely taken out everything associated with the window, and am trying to clean things up. I've noticed that the plastic round things that go in the tracks don't spin very easly on a couple. One moves very easily, so I know there is a problem. What can be done to fix this. I assume its just old-old-old grease that is causing it, but how can I get it all out of the little space?
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Aug 14, 2001 | 11:40 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Don't try to get it all out of the space, just put more in there and it will free itself.
Most the time I use a spray penetrant to free the rollers.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 15, 2001 | 07:20 PM
R.O.B.'s Avatar
I just noticed that the rollers can be pry'd off. I gave it a good cleaning, and lube, but the rollers still don't roll as easily as the one I've mentioned before. Can these rollers be replaced?
Old Aug 16, 2001 | 12:49 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Some of them , yes.
Call your local dealer.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
evan555222
Aug 22, 2015 07:14 PM
