A/C compressor question.
Old May 9, 2005 | 07:11 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I did do a search...didn't find anything.
I want to convert my Camaro to R134a. Where can I find a compressor for a reasonable price to do this?
The dealer wants $283. What should I pay? Thanks.
-Tom
Old May 9, 2005 | 08:11 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
The 134a conversion simply replaces seals and a fitting here and there, as far as I'm aware! You shouldn't need a new compressor.....
You have to replace the o-rings/seals because 134a will deteriorate the R-12 fittings.
Old May 9, 2005 | 08:18 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
You don't need to replace the compressor. New orings, new orifice tube, conversion fittings for the service ports, lower the pressure on the low side pressure switch (one-fourth turn counter clockwise) and charge with the correct oil for R134a.
Old May 9, 2005 | 08:46 PM
Engine: LT1, L400
SWEET!
Thanks for the input! That info will save me a bundle. Thanks!!
-Tom
Old May 9, 2005 | 09:05 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If you see any signs of leakage around the compressor replace it, if not go ahead and replace the above items. According my local dealer they get thier compressors from the same source as the local parts houses, no new stuff just new price. You may also want to look into other products such as freeze 12 or hotshot. They are closer to r12 as far as cooling and tend not to leak as bad as R134.
Old May 9, 2005 | 11:30 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i would recommend replacing the accumulator, if the system has empty for very long or has been opened, then the accumulator really needs to be replaced.
also, once its all back together, pull a vacuum on it with a good vacuum pump, the longer the better.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
Ian Irvine
Sep 4, 2015 08:08 AM
