Swap a TPI distributor in a TBI Firedird?
Old May 9, 2005 | 11:22 PM
Bryan85TA's Avatar
I had built up a 305 which came out a 1985 TPI LB9 a while back and need to put in a 88 firebird which is already an L03. Im pulling the 88 motor which is junk and putting in the 85 motor. Im staying with the tbi setup and have a holly throttle body injector and more goodies.Got the pre87 manifold to fit and adapter plate for the tbi. Now I would like to take advantage of using the TPI Distributor because it has the accel cap and coil. Is it possible, and is so anybody have wiring info?
Old May 9, 2005 | 11:48 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: Swap a TPI distributor in a TBI Firedird?
Originally posted by Bryan85TA
I had built up a 305 which came out a 1985 TPI LB9 while back and need to put in 88 firebird L03. Got the pre87 manifold to fit and adapter plate. Now I would like to take advantage of using the TPI Distributor because it has the accel cap and coil. Is it possible and if anybody knows exactly how can i get some help?
Sure, I don't see why it wouldn't work, but isn't Accel garbage? What benefits would you get versus using the stock one? I mean, regardless, it's still an LO3.
Old May 9, 2005 | 11:50 PM
Damon's Avatar
I'm not sure if it's just a wiring issue (large cap early style computer controlled HEI being run by an ECM/wiring harness that was designed for a later small cap divorced coil computer controlled HEI system). Power and tach connections are pretty straight forward, but I don't know if you can just patch the different wiring harness from the ECM into the early-style large cap distributor pin-for-pin.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
tero
Aug 6, 2015 06:34 PM
