to re-ring or not
Old May 9, 2005 | 07:54 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
to re-ring or not
HI, I have a 383, that I took out of my wreck. I did a leakdown test and there was a lot of air leaking past the rings, but compression was good. I was going to buy a re-ring kit off e-bay, after I measured the cylinders. Is it worth the time. Should I just put a bigger oil pan on, and drive it till it blows. It burned a quart every 200 miles.
Also there was no pilot bearing in the crank, would this cause a vibration.
Old May 10, 2005 | 05:10 AM
ede's Avatar
ede
if you don't have a manaul you don't need a pilot bearing and it wouldn't cause a vibration. a quart of oil every 200 miles is time to find and fix the problem.
Old May 10, 2005 | 06:51 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
it is a manual thanks.
midge54
Aug 4, 2014 08:07 AM
406ciZ28
Apr 3, 2014 08:37 PM
firebird904
Dec 3, 2010 09:03 PM
