Oil Pressure Switch on '89 IROC Z
Old May 9, 2005 | 07:58 PM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Can anyone tell me what size socket I need to remove the Oil Pressure Switch (some call it the oil pressure sending unit) on an '89 IROC Z with the TPI 305?
I found out the oil pressure swich socket made by Lisle is too small for the original switch, but fits the replacement just fine. I need to get the old one off as soon as possible.
Thanks in advance.
Old May 9, 2005 | 08:09 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
How about an adjustable wrench....?
Old May 9, 2005 | 08:13 PM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
...no way an adjustable will come close to fitting in that tight little area. I can't even get an open end or box wrench at it.....gonna need to be a socket.
Old May 9, 2005 | 08:16 PM
Nixon1's Avatar
Ah...well wish I knew what to tell ya. Been a while since I had my third gen... If you can get the adj. wrench on the fitting AT ALL even if you can't turn it, you could always dial it in as close to the right size as you can, and then go digging through deep-well sockets and try to match the socket walls up to what you've got on the wrench. It's sloppy, but it could work. That's all the help I can offer, sorry
Old May 9, 2005 | 08:58 PM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Yea, I actually tried to get a dial caliper on it and it measures about 1.180" or 1.190" which would mean that its about a 1 3/16" or 30 mm, but I was trying to verify this before buying a deep wall socket. BTW, this is the switch/sender located above the oil filter.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
TA8487
Aug 16, 2015 12:21 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
