Where is the fuel pump relay?
Old Aug 14, 2001 | 11:30 AM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
I left my Firebird book at some guys house so I'm asking a stupid question. Where is the fuel pump relay? I want to discharge the fuel pressure without getting it all over the engine so I was going to run it down.
Old Aug 14, 2001 | 01:21 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Uh, what year firebird? What engine? If it's TPI (I'm assuming) then it's on a bracket on the driver's side firewall. There are three relays there, two for the fans and one for the fuel pump. But be forewarned, unplugging the relay won't necessarily work. You may have an oil pressure switch which activates the fuel pump once you have a certain amount of oil pressure. When I unplugged my fp relay the car started anyway, much to my dismay.
91 Z28
Come see The Vicious...
Old Aug 14, 2001 | 01:23 PM
nebulous's Avatar
Heh I did it the old fashioned way, listen for the click....
Old Aug 16, 2001 | 03:05 AM
FiReBReTHa's Avatar
ya, same as he said, driver side, two little boxes inside of a bracket, top, easy to see...
Old Aug 16, 2001 | 04:38 AM
nativ's Avatar
look for fuse. earlier models it is in fuse block. later models in line fuse next to battery screwed to inside fender wall close to hood
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
